65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Curtain wall by line
Sat, Feb 13, 2010 at 12:09:01 AM | Curtain wall by line
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010 classic UI
okay- i have a curved wall- i put an opening in the curved wall-
i fill the opening with a curtain wall by selecting "curtain wall by lines"..
i first pick the front top edge of the opening and then
pick the botton front edge of the opening- and then a straight
piece of flat glass appears.. i break up the glass with evenly
spaced grid lines and the glass rounds out to the curve of the wall..
(there is NO properties at this point to choose how far from the edge
i might like that glass to sit)- then i place mullions on all the edges of
the glass and grid lines.. the glass does not move and the mullions
stick out from the wall and don't even touch the glass..
the is NO PROPERTIES anywhere to be found..
how do i adjust the position of the glass and the mullions?
but guess what! the glass stays down against where the wall
is cut- the mullions are not against the glass and they just stick
out from the wall.. NO PROPERIES to change anything..
Sat, Feb 13, 2010 at 6:47:23 AM | Curtain wall by line
4 Stars: 202 Votes
Pick in the Curtain wall then go to the type properties and change the parameters like you want..
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:12 AM
Curtain Wall Issues_Edge Joint
Fri, Jun 1, 2007 at 1:36:42 PM
curtain wall sketch snapping problem
Wed, Aug 12, 2009 at 8:54:08 AM
revealing hidden curtain grid
Mon, Sep 8, 2008 at 3:55:03 PM
curtain wall cuts when close to floor line
Thu, Aug 27, 2015 at 4:48:49 PM
Page generation time: 2.3727
