136 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Can't see Truss under roof
Fri, Feb 12, 2010 at 3:40:24 PM | Can't see Truss under roof
jnovella1520
Hello,
I can't seem to figure out how to get a truss to show in plan view under a roof in Course detail level.  I've tried all the typical truss families from Revit and they all don't show.  Am I using the wrong roof, settings, etc.  I've changed the roof transparency to invisible, which allowed for the truss to show, but now all the cmu walls won't show hidden under the roof.  Has anyone else ran into this problem and/or found the fix?  Thanks
Sat, Feb 13, 2010 at 7:06:07 AM | Can't see Truss under roof
4 Stars: 202 Votes
Try to edit that beam family go to "Visibility" and turn on "Coarse" then load into project and check.
Edited on: Sat, Feb 13, 2010 at 7:06:24 AM
Sat, Feb 13, 2010 at 2:31:05 PM | Can't see Truss under roof
Kardiff
5 Stars: 3 Votes
If that fails and you are doing it just to print out a drawing.  you could cheat and use the detail line tool and just draw them onto your sheet view.
not ideal but it'll work
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Tue, Feb 16, 2010 at 11:02:29 AM | Can't see Truss under roof
jnovella1520
Typhoon,  I tried what your showing but when I open the truss family for edit its only showing the symbolic lines for top chord, bottom chord, and web...and when I do click on the lines and edit the visibility they are showing that coarse is checked.  I thought the truss family was different than the beams and joist family or is there a truss family that acts like them?  Thanks
Kardiff,  Ya thats what I did on the last project too.  We don't use the truss that much, but when we do we've had to fudge it.  I was just hoping there was a step I was missing...
 Also thank ya'll for your help.
Tue, Feb 16, 2010 at 4:05:55 PM | Can't see Truss under roof
TKennedy
4 Stars: 7 Votes
Try making your roof trasparent.
Tue, Feb 16, 2010 at 4:29:06 PM | Can't see Truss under roof
jnovella1520
TKennedy, I've tried the "Graphics Override" and changed the roof to transparent, which worked, but the project is mainly load bearing cmu and all the walls going to the bottom of the roof turned to solid lines and I need them to stay hidden.  I thought about changing/overriding the properties of the walls at the roof level, but it doesn't seem like I should have to be doing that...Thank you for your help.
Hip roof Truss
Fri, Nov 10, 2006 at 10:18:50 AM
roof truss install
Tue, Feb 10, 2009 at 9:00:57 PM
12
Revit roof... truss vs. rafter
Wed, Dec 18, 2013 at 11:26:23 AM
Truss overhang help
Wed, May 23, 2012 at 8:32:24 AM
Grey out Truss
Thu, Jan 5, 2006 at 10:04:53 PM
Page generation time: 0.7353
