Forums >> Revit Structure >> Technical Support >> Beam start/end extension
Fri, Feb 12, 2010 at 10:08:45 AM | Beam start/end extension
ximenin
Hi,this is driving me crazy. It couldn't be so difficult.Ok, let's go. I'm drawing a simple porch, that is, three columns and a pair of beams. (from the library, rectangular precast columns and I-shaped beams)Start and end extensions are set to 0 at beam's configuration... how can I get the beams sit on the columns?Thanks!!!
Fri, Feb 12, 2010 at 10:40:38 AM | Beam start/end extension
Kardiff
5 Stars: 3 Votes
If you go to your level plan and highlight your beam tere will be 2 blue arrows at either enddrag them to their desired place to change the beam to it sits on the column
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Feb 12, 2010 at 10:59:48 AM | Beam start/end extension
ximenin
Ok, this seems to work, but the only way to do it is modifying one by one?
Amending Construction Start/End Extension
Wed, Feb 11, 2009 at 4:57:07 AM
Any way to determine which end is Beam/Joist Start or End
Mon, Feb 1, 2010 at 7:10:23 AM
Stuctural beam extension visibility
Wed, Mar 7, 2007 at 5:27:12 PM
Beam joint extension
Fri, Jun 18, 2010 at 12:42:56 AM
revit extension output : column not visible at beam end support
Mon, Aug 25, 2008 at 5:44:34 AM
Page generation time: 4.2605
