71 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Loading coping stones into the model
Fri, Feb 12, 2010 at 4:18:45 AM | Loading coping stones into the model
avonrower
Revit is quite new to me and I'm having trouble bringing in coping stones to my model. I have them loaded into the project browser but can't find the location to load them into the model... do I need to be in a specfic view or am I missing something?
Thanks,
Fri, Feb 12, 2010 at 5:30:41 AM | Loading coping stones into the model
Kardiff
5 Stars: 3 Votes
They should be loaded in as a 'family'If you look on the project browser under families there is a good chance you will find them under 'generic model'If not, open up the family and press 'category parameters' on the ribbonyou can check/set which family it would fall underSo you could set it as a generic model, or a category you feel would be easy to remember
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Feb 12, 2010 at 5:39:32 AM | Loading coping stones into the model
avonrower
thank you, it's there! I found out it's also a sweep which makes another conundrum, but at least I have a slight idea how that works!!
Fri, Feb 12, 2010 at 6:17:15 AM | Loading coping stones into the model
Coping stones are usually not a generic model but they could be a stand alone (parametric or not) family of the category you want.  Usually, they are created from a profile that is used to define a sweep.  When the profile is created, you have to assign it to the proper category of use in "catagories and parameters" in the profile family.
Truss - coping frame members
Mon, Aug 16, 2010 at 5:51:36 AM
Finish Profile at Stone Coping [ 1 2 ]
Tue, Jul 29, 2008 at 1:20:48 PM
16
How can I radius my coping of steel beams?
Mon, Oct 25, 2010 at 5:02:19 PM
coping the girder
Sat, Nov 13, 2010 at 3:16:51 PM
Parapet Wall Coping as a sweep
Tue, Feb 19, 2008 at 9:35:44 AM
Page generation time: 0.6414
