58 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Move objects with level change
Mon, Sep 12, 2005 at 1:35:14 AM | Move objects with level change
Sparrow
I am trying to change the height of my Ground level from 0m to 576m, but when I try it says "Can't create roof footprint" and cancels the action. The roofs are associated with the Ground level. Anyone know how to get around this?
Mon, Sep 12, 2005 at 3:23:46 AM | RE: Move objects with level change
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
How are you changing the height? The correct way would be to use the relocate project tool in elevation then move the project up by 576m... This should work if done in this manner.
Mon, Sep 12, 2005 at 10:11:16 PM | RE: Move objects with level change
Sparrow
WORKED PERFECTLY - THANKS.
Move a level without deleting objects on that level
Tue, Jul 4, 2017 at 5:20:23 AM
How to move a single level datum without moving anything in model
Tue, Sep 29, 2015 at 1:53:58 PM
Changing Level Heights and having corresponding objects move
Wed, Nov 29, 2006 at 5:03:12 PM
objects from 2nd level appearing in 3rd level why?
Mon, May 20, 2013 at 4:35:41 PM
How i can change the level with out move the building
Sat, Apr 29, 2017 at 8:03:05 AM
Page generation time: 2.4918
