61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Split region on a wall surface Revit 2010
Thu, Feb 11, 2010 at 2:07:19 PM | Split region on a wall surface Revit 2010
aaronkennedy
I am trying to split the surface on a wall to create a brick wainscot.  As you can see from the attached screen shot I have split the region, the exterior finish material.  I want to  make the material below the split brick with a different thickness.  Does anyone know how to do this?  Is it easier to do it with a stacked wall?  I thought this was the easy way to do it.
Any help will be appreciated,
Thank you,
AAron
Thu, Feb 11, 2010 at 2:18:08 PM | Split region on a wall surface Revit 2010
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
I'm pretty sure that if you split regions on a wall, the thickness of the material will be the same for each region.  I usually make walls like this by creating a stack wall with the brick wall type on the bottom, then whatever type of wall on the top.  You can stack a few different wall types to get the varying brick thickness or use sweeps and reveals if it is only sections that are of varying thickness'
stanmpd
Belz A&C
Memphis, TN
join wall with split region with wall without split region
Wed, Dec 21, 2011 at 8:30:02 AM
SPLIT SURFACE and GRADE REGION
Thu, Sep 15, 2005 at 7:54:25 PM
Split Region Wall Foundation Issues
Wed, Jun 1, 2011 at 5:36:26 PM
Split surface & paint vs. schedule
Tue, Oct 12, 2004 at 3:34:33 AM
Split Region and Rendering Questions
Tue, Jun 24, 2008 at 8:40:57 AM
Page generation time: 4.6919
