64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Viewport bounding box line weight
1 Posts No Rating |
I'm working on formatting several sheets with several interior elevations on them. What I've been doing is creating an elevation then making sure the crop region is visible. Next I slide the view onto a sheet. Now what I would like to do is edit the line weight of the crop region that is now on the sheet because the default thickness seems to be set to 1. I've been able to do it successfully for each individual elevation on the sheet by selecting the view then activating the view < selecting the bounding box < then right clicking and selecting override graphics in view < by element < then modify the line weight here. The problem is this is not effective if you have hundreds of interior elevations. I've tried editing the system family viewport and found I could only edit the title line and not the bounding box. I've also tried modifying every annotation object I have within object styles and still nothing changing. Please respond if you know how to change the line weight of every viewport box simultaneously. Thanks
Viewport Title Line Weight |
Wed, Mar 12, 2008 at 8:14:52 PM
viewport title with line question |
Tue, Jul 8, 2008 at 11:38:17 PM
viewport annotation box |
Mon, Jun 2, 2014 at 8:49:40 AM
line weight question |
Fri, Jul 20, 2012 at 8:24:10 AM
Viewport Text |
Wed, Mar 9, 2016 at 10:00:08 PM
Members: | 2017784 | Objects: | 22948 | Forum Posts: | 152213 | Job Listings: | 3 |
