63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> How do you create a 24" gable at the top of a hip roof
2 Posts No Rating |
Is there an easy way to create a 24" wide gable at the edge of a hip roof.
I attached a photo of what I am trying to create.
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
In your roof sketch split the edge to host the gable into 3 segments centred around the ridge line. Then select the centre line of the splits and apply a pitch to it, and set the desired offset from the base...
2 Posts No Rating |
"In your roof sketch split the edge to host the gable into 3 segments centred around the ridge line. Then select the centre line of the splits and apply a pitch to it, and set the desired offset from the base..." Thanks Mr. Spot....That worked exactly to what I needed.
"Dutch Gable" roof |
Mon, Mar 31, 2008 at 1:35:54 PM
Can't get Gable roof to Join Hip roof |
Wed, Aug 20, 2014 at 3:56:33 PM
small hip |
Sat, Nov 12, 2011 at 6:01:28 AM
Partial Hip Roof |
Tue, Jun 26, 2007 at 3:22:10 PM
Issue Aligning two roofs that exist on different levels. |
Tue, Mar 20, 2007 at 3:33:15 AM
Members: | 2017463 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
