63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> lossing colour when importing items to a project
Sun, Feb 7, 2010 at 2:17:40 PM | lossing colour when importing items to a project
ianmurray763
I am really struggling, every time i import an item into one of my projects, despite having colour in the 3D Image as soon as i render a 3D view some items come up grey (probably the default setting) i have tried various things with limited success, mainly changing the item material away from default to default wall this achieved success for the item but also changed the colour of the wall structure to the same, any ideas where i am going wrong
Thanks for reading
Ian
Sun, Feb 7, 2010 at 2:23:20 PM | lossing colour when importing items to a project
ianmurray763
PS I am selecting a render material for items
Mon, Feb 8, 2010 at 8:22:46 AM | lossing colour when importing items to a project
3.5 Stars: 396 Votes
Here is a very important rule to remember:  THE PROJECT RULES!
What that means is if a material is set in the project, it doesn't matter what poperties the material is set to in the family editor.   Materials need unique names created and set initially in the family.  Once that family is loaded, you have to change the settings in the project OR remove the family and purge the material definition from the project.
Remember, use unique names if you want unique materials.  "Aluminum" may be in many different families but "Aluminum - white" might be what you need.
Thu, Feb 11, 2010 at 6:32:14 AM | lossing colour when importing items to a project
ianmurray763
Thanks that helps loads i should have thought that out
Regards
Ian
Colour/Material change in project?
Thu, May 24, 2007 at 2:21:03 AM
Colour of Component
Sun, Feb 15, 2009 at 4:59:18 AM
Windows and Door Come Out Wrong Colour After Rendering
Sun, Jul 12, 2009 at 2:30:25 PM
Changing the Colour of a Material
Fri, Nov 16, 2012 at 3:21:06 PM
familiy creation
Tue, Dec 2, 2014 at 8:47:49 AM
Page generation time: 4.5020
