47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Gable End Rake Detail
Fri, Feb 5, 2010 at 5:53:27 PM | Gable End Rake Detail
newengarch
Has anyone mastered the process of creating accurate extended rakes that are correctly depicted in Roof Plan & Elevation? I ask this because when we create a roof in Revit if we extend it beyond the gable wall  it's actual structural Depth is shown in Elevation, which in most cases is not what we want. The nicely detailed rake trim in most cases would not be a 2X10 rafter depth, if that happens to be the make-up of your roof. If we create a roof and do not extend it beyond the gable wall it still shows up in elevation with its structural depth appearing. Do we hold the roof back to outside face of stud then cut profile the wall and then sweep a rake profile along the slope. Doing that results in a portion of roof (in Plan) not being depicted. I am finding it very difficult to interface Rake (extended or not) with Soffit, Gutter & Fascia using Revit. I'm at this point assuming a lot of these issues have to be resolve in the 2d detailng?
Any pointers would be appreciated!
Thu, Feb 18, 2010 at 3:38:41 PM | Gable End Rake Detail
robinballew
robinballew Avatar
3 Stars: 4 Votes
No 2D. You have a few ways to do this.
1. Model the roof as only the shingles and sheathing. I model the structure using actual 2x_ material so if the 2x10 don't go out side the gable wall I don't draw them. This way you can add the fascia or detail using a profile.
2. Model the roof as a full thickness. ( sounds like what you are doing ) Create an in-place family as a roof and select void extrusion. Draw an area to be removed from the roof. You can then add a fascia or detail again using a profile.
Good luck..
BallewDesigns.com
Thu, Feb 18, 2010 at 3:54:55 PM | Gable End Rake Detail
3.5 Stars: 395 Votes
3RD WAY...
Create your main roof to the face ofwall and a second roor for the outlooks... then join geometry.  As long as your shingles are a layer.... Easier than the void.
Fri, Feb 19, 2010 at 10:34:59 AM | Gable End Rake Detail
newengarch
Thanks for taking the time to response. Much appreciated. Can't wait to try your suggestions out.
Thu, Jun 22, 2017 at 2:43:05 AM | WWHub
KennedyDrafting
WWHub - Have you developed any new and improved way to do this since 2010?
Quoting WWHub from 2010-02-18 15:54:55
3RD WAY...
Thu, Jun 22, 2017 at 4:47:46 AM | Gable End Rake Detail
Not really, as you know by now, we are all constantly changing as our needs change so, now I might do an in-place void working in elevation and selecting the face end of the roof as my work plane... Not quite what Robin said.
And if you do this, remember extrusions from a workplane might have to be positive or a negative offset from the plane with a positive.  I can never remember what the rule is here for front/back & left/right so I do it and reverse it if needed.
Edited on: Thu, Jun 22, 2017 at 9:05:31 AM
Tue, Jun 27, 2017 at 9:54:03 AM | Gable End Rake Detail
tim123
4 Stars: 19 Votes
The direction of the extrusion depends on the direction that the reference plane or grid was drawn from.  From the South, a grid drawn from right to left will extrude towards you, while a grid or ref plane drawn from left to right will extrude away from you.
Tue, Jun 27, 2017 at 10:11:04 AM | Gable End Rake Detail
Ah ... if only we could get our users to draw RP's in the same direction.   Even though I explained this many times, users often draw their column lines in different directions then have to individually change the bubble end in every plan view.  They are getting it but some just don't care.
PS.... The answer I gave above used the plane of the roof, not an added reference plane.
gable returns
Thu, Jul 15, 2010 at 10:37:11 PM
Gable end of Roof
Sat, Sep 9, 2006 at 5:31:52 PM
soffits on gable ends
Fri, Aug 15, 2008 at 4:50:24 PM
Gable End Fascia
Wed, May 23, 2007 at 5:45:50 AM
Roof fascia return
Thu, Dec 12, 2013 at 11:05:13 AM
Page generation time: 1.2878
