61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> SURFACE PATTERN ROTATION
Fri, Feb 5, 2010 at 12:56:02 PM | SURFACE PATTERN ROTATION
ontarioparis
I"m having a brain fart. How do I rotate a pattern to go from horizontal to vertical? specifically 'wood board' model pattern. I recall doing this before but cannot remember what I did now. Please help!
Fri, Feb 5, 2010 at 12:57:52 PM | SURFACE PATTERN ROTATION
ontarioparis
FYI this is for revit 2009
Fri, Feb 5, 2010 at 1:01:09 PM | SURFACE PATTERN ROTATION
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
use the align tool
Fri, Feb 5, 2010 at 1:05:34 PM | SURFACE PATTERN ROTATION
ontarioparis
I tried align but to no avail. i tried aligning the wood board longest line with a nearby vertical wall (to make the pattern go to 90 degrees). Is there another element i should create to use as an alignment?
Fri, Feb 5, 2010 at 1:10:03 PM | SURFACE PATTERN ROTATION
If you can find any part of the pattern that you can tab select, select it and rotate.
Fri, Feb 5, 2010 at 1:27:46 PM | SURFACE PATTERN ROTATION
ontarioparis
thank you thank you thank you!! that worked!! phew! Now on to the rest of the drawing...
much appreciated!
problems with metal roof surface pattern
Tue, Mar 10, 2009 at 2:02:45 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Pattern Based Panel - Rotation Error
Tue, Feb 16, 2016 at 9:35:06 PM
Page generation time: 0.5032
