16 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Curtain Wall Panel - Revit 10
2 Posts No Rating |
Hi, I am fairly new at working with Revit and I find these forums very helpful. I am trying to create a curtain wall with metal panels that wraps a cube on 5 of its sides (4 vertical and 1 bottom). I have 2 questions on how to construct the panels. 1. I am using mitre joints at corners, thus some panels have one side at 45 degrees while others will have 2 adjacent sides at 45 degrees. The problem is that the panels are hollow on the inside and I don't know how to extrude a void with 2 adjacent sides at 45 degrees?2. To construct the corner panels (one side at 45 degrees) I modified the family of a typical rectangular panel. In the family edit file I have 4 reference planes for each side and a center reference plane. For some reason when I load it back into the project one of the sides does not follow the curtain wall grids. What can I do to make sure that every time I modify my curtain wall grid lines, the panels will follow?Thanks a lot
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
after you build your extrusion you could use a void to cut the other 45 degree panel edge
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
I don't know how big this cube is but I may have modeled all the faces as the panel and done all the mullions as one in-place family. May be simplier than using the CW. If it a large cube and you have doors in the side, I would do the sides as CW and do the bottom in-place and all of the unique mullions in place.
Edited on: Fri, Feb 5, 2010 at 1:14:32 PM
2 Posts No Rating |
The cube is 7x6x5.6 m and each panel is around 1.5x1.5m. There are doors and windows on the sides. I will try the CW + in place panels and mullion for the bottom. About my second questions, do i have to use parameters or lock the sides of the panel to the reference plane in order for my panel to always fall between the CW grid lines? Right now I have 3 sides that respect my CW grid lines and one side that just goes beyond.
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:11 AM
curtain wall panel losses end - edge |
Tue, Jul 15, 2014 at 7:04:22 PM
Curtain wall - empty panel issue |
Mon, Mar 25, 2013 at 2:34:28 PM
13
Curtain Panel Backwards Glitch |
Sun, Jul 10, 2016 at 11:32:21 PM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
Members: | 2026030 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
