116 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> copy groups from level to level
Fri, Feb 5, 2010 at 6:38:12 AM | copy groups from level to level
vrijaya
Any idea why a group of walls cannot be copied from one level to another, the paste aligned command is inactive. it worked once but it doesn't work anymore...
Veronica
Fri, Feb 5, 2010 at 6:59:37 AM | copy groups from level to level
To copy from one level to another, you are better of using the select levels option.
Fri, Feb 5, 2010 at 7:25:22 AM | copy groups from level to level
vrijaya
Can u be a little bit more specific, I think I haven't used this selection option yet.
Thanks.
Veronica
Fri, Feb 5, 2010 at 7:48:31 AM | copy groups from level to level
Thread Post Kudo! #4
2010 - Select an object and pick the copy option on the clipboard.  Then click the down arrow on the paste aligned and you will see the select level option.  Choose your level (or levels - multiple).  The element wll past at the sme relative xyz location per floor.  You can do this from plan/section/elevation views.
Fri, Feb 5, 2010 at 7:55:07 AM | copy groups from level to level
vrijaya
thanks a lot, I discovered the problem, I was using the wrong COPY button, instead of COPY to Clipboard.
Veronica
Can't copy furniture group to different level view
Thu, Jun 7, 2018 at 10:43:55 AM
Groups - Copy / Placing
Wed, Aug 16, 2017 at 9:52:28 AM
Linked, then Bound, Groups and Levels they reside on?
Wed, Nov 26, 2014 at 4:22:03 PM
copy new level
Mon, Oct 31, 2005 at 6:31:02 PM
Linked Architectural Model containing groups
Mon, Feb 16, 2015 at 7:38:47 AM
Page generation time: 0.6634
