Im busy exploring the possibility of doing an organic design in revit 2010 whereas i would usually stick to modeling it in MAX. The only problem i have at the moment is the openings. I started off with a free form mass and made walls by faces. Then made openings by using a generic wall based fam. NOW, the Q is, how do i make a window frame and glazing etc to fit the opening. The glazing will obviously have to be faceted i.e. a curtain system, but how will I get the opening and the curtain system to coincide and still accomodate changes? The attached images is just a quick 30min test (its not the design!!!!!! haha) I'll try get permission from the client to post the design images, but hes pretty secretive and wants to keep a very low profile. Thx in advance peeps!
Edited on: Thu, Feb 4, 2010 at 1:55:25 AM
9 Posts No Rating |
HI - I am creating structures similar. Could you tell how you created those or if you guide to some videos or tutorials. I have never really played around with conceptual mass. I am attaching a photo of an entrance and window displays. Your reply will be greatly appreciated ! Thanks, Ananya
Geometry works like in every modelling program. You can make sweeps, but you need to define rails, and profiles. You can make an extrusion, if you define a profile, and a line to host it. You can make a Bolean substraction, only if you have a main object, and a intersected object to substract (void). You can make a loft, if you have some profiles to describe the changes of the loft. You can make a revolution, if you have an axis and a profile. Thats all. You can describe almost everything with those. And the original question was, how to cut holes on a loft? >_> well, you can do the loft in several ways, i do it with an adaptive component as a profile, hosted in new elevation planes ( you can add more planes clicking on create planes, and with the plan plane as host), then i choose all the profiles, and click "creategeometry". After that, on plan view i create a rectangle, create a void from it, and cut the loft. Tadaaah xD i add a sample to that original question. The procedures are on youtube, or in revittod.co, but you have to imagine the solution to the geometry.
