62 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Room Tag w/ Dimensions and other calculations
![iamian33 Avatar](user_avatar/135203.jpg)
148 Posts No Rating |
Greetings. Does Revit Architecture 2010 provide the ability to create a room tag that includes: - the dimensions of the space (ie. 8'-9" x 12'-3"
? - the occupant load based upon the area of the room?
- useable / rentable (BOMA) square footage calculations?
I was advised by my reseller that 2010 had overcome this issue and will support calculations using the area or volume of a room ... TRUE? If so, can someone point me in the correct direction? :o) Ian
Ian Shafer
Principal Consultant
True North S&F Consultants |
You can schedule this information but it can not be placed in tags parametrically...
bummer ... but thanks for your input. Maybe Autodesk will get there. They should 'borrow' this from Autocad :o)
Ian Shafer
Room Dimensions in Tag Family |
Sun, Aug 31, 2008 at 9:23:36 PM
automatic room dimensions tag |
Fri, Nov 8, 2013 at 2:16:28 PM
Room Tag & Room Dimensions |
Mon, Mar 13, 2006 at 3:11:05 PM
ROOM TAG HEADACHE!!!! PLEASE HELP |
Thu, Dec 4, 2008 at 12:15:23 PM
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
