36 Users Online (35 Members):
Forums >> Community >> Newbies >> Vertical Tile and Shower Frame and Glass
I need to apply vertical tile to the shower. I do not want to split the wall and put tile on a split wall layer. Is there another way I can add tile to the wall to go up a specific height? The shower frame is made of aluminum with the translucent glass. I have found the base of the shower in the dowloads. Is the framing and class combination there as well or will I have to "make" the framing (using sketches and extrusions) and add the translucent glass?
In regards to the wall you can add the tile as a layer in the structure of the wall type. Then expand your preview pane and switch to section view. Click modify and select the top of the tile layer and unlock it. You can then specify in the element properties the top extension distance, which would be the difference between the height of the wall and the height of the tile.
For tile walls that may only be partial height, I just use a thin tile wall and place it in front of my host wall - then use join geometry.
Frameless shower glass door |
Fri, Jul 9, 2010 at 11:50:11 AM
Glass Shower Doors |
Mon, Jun 16, 2014 at 8:58:13 AM
Glass Shower Door |
Thu, May 29, 2014 at 7:44:32 AM
Domestic sliding shower screen |
Tue, Sep 19, 2006 at 9:51:20 PM
Glass louvers/ brise soleil |
Mon, May 25, 2015 at 12:18:27 AM
Members: | 2056535 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
