29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall meeting topography question
Tue, Feb 2, 2010 at 9:52:20 AM | wall meeting topography question
col9000
Hi,
If I make a simple garden wall sitting on topography, how do I get a line to appear where the wall meets the topographic surface (when viewed in 3D, hidden line style)? My wall starts below and is penetrating through the surface level of the topography. Tou can see the joinin the shading with edges style (see attached)...
Thanks in advance!
C
Tue, Feb 2, 2010 at 4:24:14 PM | wall meeting topography question
Have you learned about join geometry.  If not, you can read about it in your help.
Tue, Feb 2, 2010 at 4:41:50 PM | wall meeting topography question
col9000
yeah i have... but certain things such as this it won't allow me to join. If i select the wall first I can't select the topography, and vice versa
Wed, Feb 3, 2010 at 3:45:57 AM | wall meeting topography question
4 Stars: 203 Votes
Of course Not, you CAN'T join walls With toposurface (not until now, i don't know in Revit 2011...), did you create a PAD by the Exterior perimeter of those Walls?
Edited on: Wed, Feb 3, 2010 at 3:46:54 AM
Wed, Feb 3, 2010 at 6:14:36 AM | wall meeting topography question
col9000
No i didn't actually, i didnt realise you had to... I've used them before so i know how they work in general. however this time i didnt because I wasn't sure how to make it fit the shape of foundation im using (its a strip foundation, see image) which cuts under the ground adjacent to the building.
Wed, Feb 3, 2010 at 12:18:44 PM | wall meeting topography question
4 Stars: 203 Votes
Why don't you create a thinnes PAD below your slab around your exterior walls and check if it work?
Edited on: Wed, Feb 3, 2010 at 12:57:51 PM
A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
Tue, Nov 22, 2011 at 6:07:37 AM
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
Giving topography thickness when rendering
Thu, Jan 22, 2009 at 9:42:06 AM
Portland Revit Users Group Meeting being held on 03/24/05
Mon, Feb 28, 2005 at 8:03:29 PM
Portland Revit Users Group Meeting on 03/24/05
Mon, Feb 28, 2005 at 8:02:19 PM
Page generation time: 1.4665
