67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Text Field
Mon, Feb 1, 2010 at 4:08:47 PM | Text Field
ChelesaTheRad
I am working in Revit 2010 and have a question concerning the text format. When typing a series of notes that are numbered, the text field does not align the text separately from the numbers. AutoCAD has the capacity to use the number “wizard” (also used in Windows Word programs) so that when you get to the end of a text line and hit enter the following number starts the next line and the text is spaced away from the number appropriately. I was unable to find the ability to do this in Revit. Is the text command set up for this? Where and how? I am currently cheating the program by using two text fields, one with the coorsponding numbers and the other with the notes.
Mon, Feb 1, 2010 at 5:07:11 PM | Text Field
emgeeo
3.5 Stars: 7 Votes
I use the tab key for formatting.  see attached image
Mon, Feb 1, 2010 at 6:04:13 PM | Text Field
jarosa
jarosa Avatar
4 Stars: 5 Votes
I use a Key Schedule. See David's blog entries. Not perfect but clean and fairly efficient. I do all my different notes in a separate schedule; concrete, wood, general, roof, etc. Because they are schedules you can place them on the sheet you want and/or set up a notes sheet in your template. Just another option until we get a serious text editor.
http://do-u-revit.blogspot.com/2009/03/jumpy-text.html
http://do-u-revit.blogspot.com/2009/03/text-notes.html
Schedule -Adding column totals to text field parameters
Mon, Mar 9, 2015 at 5:27:46 PM
How to switch off the value field from dimension.
Wed, Mar 13, 2013 at 3:21:52 PM
11
Adding Optional Text Field to Keynote Tag
Thu, Nov 13, 2008 at 8:52:48 AM
How can I make a new tag (with new text field on the label) for Area plans?
Thu, Jul 5, 2018 at 1:51:28 AM
How do I create a Room Tag that has a text field that I can add comments too?
Mon, Nov 20, 2017 at 4:22:22 PM
Page generation time: 0.5015
