14 Users Online (14 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Sketchup topo to Revit
Mon, Feb 1, 2010 at 12:35:35 PM | Sketchup topo to Revit
jgmas
Some time ago I watched a video online on how to export an existing site from Sketchup to Revit. I cannot find the video anymore but maybe some of you know how to do it and explain me how to...
thanks
Mon, Feb 1, 2010 at 12:54:10 PM | Sketchup topo to Revit
4 Stars: 201 Votes
Go to the Site plan view then "Import CAD", change the extension to SKP, select the Sketchup file, check the units, colors... then OPEN, now in Toposurface "Create from import>Select import instances" pick in the skp file, i hope you have that with elevations...
Mon, Feb 1, 2010 at 1:37:38 PM | Sketchup topo to Revit
jgmas
Thanks thyphoon,
importing the file worked the only thing is that when I tried to create the topo from the  "Create from import>Select import instances, that did not work.
any ideas/solutions?
 what do you mean by " i hope you have that with elevations..."?
Tue, Feb 2, 2010 at 3:24:47 AM | Sketchup topo to Revit
4 Stars: 201 Votes
The model must have "Elevations Z" - (points with x,y and Z), i never used sketchup "Site" model to create my toposurface in Revit, i always use DWG files with contours lines with right elevation (Z)...
Thu, Sep 5, 2013 at 5:58:25 AM | Sketchup topo to Revit
JarrodJooste
https://www.youtube.com/watch?v=R1X8Ux_4wJI
Best way tutorial of this ive found to date.
Revit to SketchUp
Thu, May 28, 2009 at 9:44:11 AM
lines on topo surface
Wed, Aug 3, 2011 at 8:37:21 AM
Sketchup to Revit
Wed, Aug 26, 2015 at 10:41:27 AM
Sketchup model into Revit
Tue, Jan 8, 2013 at 12:06:20 PM
SketchUp to Revit
Sun, Mar 22, 2009 at 6:53:33 PM
Page generation time: 5.4486
