74 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> REMOVE SURFACE PATTERN
Thu, Sep 8, 2005 at 2:05:49 PM | REMOVE SURFACE PATTERN
karok
I have a problem. i have a concrete showing up on my slab, when I create a detail of the plan. when I have the drawing at 1/8" scale or larger the hatch shows up, when it is at a smaller scale the hach doesn't. what causes this?
Thu, Sep 8, 2005 at 2:12:38 PM | RE: REMOVE SURFACE PATTERN
karok
nevermid figuired it out. i would like to know what causes that. i found a work around (overriding the detail levels for slab, and turning off slab edge).
How to remove SURFACE PATTERN GRID LINES on imported family component?
Mon, May 20, 2013 at 7:24:19 AM
Revit 2015, Conical Roof Surface Pattern Twist
Wed, Apr 22, 2015 at 8:57:44 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Page generation time: 0.8020
