99 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Listening dimension display too small
Fri, Jan 29, 2010 at 9:18:51 PM | Listening dimension display too small
JGRAY
I am new to Revit. When I select a wall the listening dimension displayed is too small to read. If you zoom in the, font just gets smaller. If you click on the dimension it displays in a box and the font size is acceptable. Is there a way to increase the font size?
I am using Revit Architecture 2010
Sat, Jan 30, 2010 at 6:37:43 AM | Listening dimension display too small
4 Stars: 203 Votes
You must learn to search in the forum, if you search for "Temporary Dimensions" you gonna see lots of thread about this...
see this:  http://bimandbeam.typepad.com/bim_beam/2007/08/how-to-adjust-t.html
Sun, Jan 31, 2010 at 12:48:40 AM | Listening dimension display too small
JGRAY
I have searched the forums and found nothing offering any help for dealing with listening dimension font size. The fixes for the temp dimensions dealing with the ini. file and changing scale do not change the size of the listening font. Do you have any other suggestions?
Sun, Jan 31, 2010 at 6:43:42 AM | Listening dimension display too small
4 Stars: 203 Votes
If you look at my image you can see i search for "Temporary Dimensions" and appears lots of threads...
"The fixes for the temp dimensions dealing with the ini. file and changing scale do not change the size of the listening font." - if you follow the instructions it gonna change the font size of the temporary dimensions, i just did, look at the second image...
small dimension box & tape measure dimension
Sat, Sep 20, 2008 at 5:05:54 PM
small dimensions
Tue, Dec 5, 2006 at 4:31:02 PM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:08 AM
18
Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 7:12:03 AM
More options in Dimensions styles
Thu, Aug 4, 2005 at 8:29:44 AM
Page generation time: 0.6004
