42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> ADJUSTING PRINTING MARGINS IN REVIT
Thu, Jan 28, 2010 at 11:41:47 AM | ADJUSTING PRINTING MARGINS IN REVIT
jetfavre
I AM PRINTING TO ADOBE ACROBAT, AND REVIT SEEMS TO ADD A MARGIN AROUND THE BORDER. IN ACROBAT U HAVE THE ABILITY TO PRINT A FULL SIZE SHEET. (IM TRYING TO PRINT A E-SIZE SHEET "30x42"Winking AND REVIT ADDS A MARGIN AROUND THE BORDER. IS THERE ANY WAY TO REMOVE THE MARGIN? I KNOW REVIT HAS A SIMPLE WINDOW PRINT DRIVER.  BUT IF I CANT PRINT A SHEET FULL SIZE KINDA MAKES IT ALL A MOOT POINT, TO DO ALL THIS WORK WHEN CAN'T PRODUCE PROPERLY SCALED DWGS.
CAN ANYBODY GIVE ME SOME INSIGHT?
Thu, Jan 28, 2010 at 1:05:15 PM | ADJUSTING PRINTING MARGINS IN REVIT
4 Stars: 203 Votes
I don't use PDF to print my drawings, only DWF but just a question: are you using a "Educational Version" of Revit?
Thu, Jan 28, 2010 at 1:15:16 PM | ADJUSTING PRINTING MARGINS IN REVIT
jetfavre
No im using revit structure suite 2010.
Thu, Jan 28, 2010 at 1:56:48 PM | ADJUSTING PRINTING MARGINS IN REVIT
mflure
Ok..
Couple of things:
1.) If your creating a E size sheet and revit it set to fit it will add the boarder automatically... make sure you have it scale to 100%...
2.) Also if it cutting the PDF to a smaller size and not to a full size E sheet you need to make sure you have the professional version of Acrobat.  If you dont it will have those problems.. Since Professional and up have the ability to print to the large format.  The standard version does not.
 Mike
Thu, Jan 28, 2010 at 2:06:26 PM | ADJUSTING PRINTING MARGINS IN REVIT
jetfavre
THANKS, I FOUND MY PROBLEM. IN ACROBAT U CAN SET UP THE SHEET SIZES THAT IT WILL PRINT TO. MY "E" AND "E1" SIZES IN ACROBAT WERE INCORRECT (THEY WERE LARGER THAN NEED BE) SO REVIT DID EVERYTHING RIGHT I WAS PRINTING TO A BIGGER SHEET THAN I THOUGHT... DUH! ONCE I FIGURED THAT OUT, CORRECTED THE MISTAKE.IT PRINTER CORRECTLY.
THANKS FOR THE REPLY.
PRINTING TO MARGINS
Wed, Mar 4, 2009 at 3:51:58 PM
Margins/Row Heights in Schedules
Wed, Aug 17, 2011 at 12:13:44 PM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:16 AM
18
Plotting/Printing in Revit.
Tue, Oct 26, 2004 at 9:01:59 AM
Revit PDF writer / margins
Sun, Apr 10, 2005 at 6:40:44 PM
Page generation time: 5.2222
