Forums >> Revit Building >> Technical Support >> 2d & 3d dwfs
I recently read a short blog that Revit 2010 can now combine 2d & 3d dwf's into a single file. I was wondering if anyone out there knows if this is true or not.
Did it for a couple of years... it will also combine other files like excel and word and jpg. Create yur DWF's then open one of them and then open a seperate window's directory folder window containing what you want to combine and just drag the file and drop it into your opened DWF. I usuall use my 3D fileas the base and drop the 2D dwf's and other files into that.
I just tried it, and it seems to work.
Did it for a couple of years... it will also combine other files like excel and word and jpg. Create yur DWF's then open one of them and then open a seperate window's directory folder window containing what you want to combine and just drag the file and drop it into your opened DWF. I usuall use my 3D fileas the base and drop the 2D dwf's and other files into that. " I think he was talking about making combined 3D and 2D files right from Revit, not combining them later in Design Review.
Yes, to what TKennedy said.
I created a 3d dwf and a set of 2d ones. When I tried to drag and drop a 2d into the 3d the 3d disappeared. Is there some trick I am missing?
3D DWFs and Design Options |
Thu, Aug 13, 2009 at 2:56:11 PM
Revit on Tablets |
Thu, May 10, 2012 at 3:07:55 PM
Keynotes Hyperlinks Urls DWFs PDFs |
Thu, Aug 16, 2012 at 10:32:53 AM
Materials not exporting to dwf properly |
Fri, Oct 7, 2011 at 9:00:26 AM
Is it a bug? |
Wed, Mar 5, 2008 at 5:52:30 AM
Members: | 2115008 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
