59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Casework below countertop not visible.
5 Posts No Rating |
Hello. I have built a casework family in Revit 2010 which shows the casework below the countertop as a hidden line, which is what I want. When I load it into my project however, the lower casework is not visible. I have gone through all of the visibility settings and "Plan Rep - Below" is checked in all instances. I'm not sure what I'm missing here. Help?
9 Posts No Rating |
Check your Object Styles in the project and see if the line weights are the same. The Project Rules, and will always override your family settings.
5 Posts No Rating |
The object styles seem to be set correctly, with a dashed line for casework below. All my other casework shows up properly in the project, it's just this custom created family that is screwy.
9 Posts No Rating |
Your countertop is obscuring the cabinets below. Within the family you could turn off the countertop visibility in plan view and use symbolic lines. Conversely you could use dashed symbolic lines to represent the cabinets below.
Have you tried the "Show Hidden" tool? Modify - Show hidden - pick the counter then the cabinet.
5 Posts No Rating |
Thanks, I did the symbolic lines trick for the countertop, and that allowed me to show the casework in the desired manner.
Formulas in Tags |
Thu, Mar 20, 2008 at 11:08:07 AM
Change casework height based on countertops height |
Tue, Jan 3, 2012 at 1:19:43 PM
Countertop Invisibility |
Mon, Jan 5, 2009 at 1:46:39 PM
How do I add a countertop to the Base Cabinet - Corner Unit Angled? |
Tue, Mar 28, 2006 at 3:39:10 PM
Casework below in-place component won't show - R09 |
Fri, Dec 4, 2009 at 11:50:12 AM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
