76 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 'Seek Failed'
Wed, Jan 27, 2010 at 12:35:57 PM | 'Seek Failed'
arcitec
arcitec Avatar
I'm a Revit Architecture 2010 user, and am trying to link a Revit Struture 2010 model into ours.  When doing so, I receive the error message 'Seek Failed...', and it lists the file path.  I have tried to browse to and open the structure file, as well as auditing it, and receive the same error every time.  Has anyone else found a solution to this?
 Thanks.
Wed, Jan 27, 2010 at 12:55:05 PM | 'Seek Failed'
JPrior
JPrior Avatar
4 Stars: 1 Votes
I dont know if this helps but we had a similar issue and this post helped.
 http://forums.augi.com/showthread.php?t=29896&highlight=SEEK+FAILED
 also I read it could be a service pack issue but the post I read was from 2 years ago.
good luck
Wed, Jan 27, 2010 at 3:04:17 PM | 'Seek Failed'
arcitec
arcitec Avatar
Problem solved.
The file we received from the Structural Engineer was a local file, and had not been detached from their central file.
Seek Failed
Wed, Aug 12, 2009 at 11:16:29 PM
"Seek Failed" help!!!
Fri, Jul 27, 2007 at 3:55:46 PM
Unweildy subregion
Tue, Mar 28, 2006 at 4:19:07 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Page generation time: 0.6307
