Forums >> Revit Building >> Technical Support >> Model Surface Pattern Skewed
209 Posts No Rating |
Attached is an image of the problem. The roof is sloped and created this curved pattern from my model surface pattern set to 90. Is there a way to fix this? I have tried selecting a line in the pattern and rotating it that doesnt work.
Wierd, did you double check if this is a model pattern?
I have to modify sub elements and set the north points heights manually in order for the south edge points to remain level at 0,0. When i do that the pattern skews. Im not defining the slope by edge or using slope arrow. If i did the roof would slope but the north and south edges would tilt up. The shape becomes parabolic and changes the pattern due to shape. I was under the impression model surface patterns force the pattern onto the element at assigned angle regardless of shape.Edited on: Wed, Jan 27, 2010 at 5:08:21 PM
Edited on: Wed, Jan 27, 2010 at 5:10:31 PM
quinn...I know this thread ended a long time ago, but I was curious if you ever found a solution to the skewed / warped surface pattern problem you were having. I am having the same trouble now in 2015. Thanks.
The pattern is not warped, the surface is warped. Parallel lines in 2D will not remain parallel in a 3D warp.
Draw parallel lines on a sheet of paper then roll it up into a cone and see what happens
There is a an option in properties that allows you to change how a surface pattern behaves according to its curved surface. Problem solved.
Surface Pattern Skewed Error |
Mon, Jan 25, 2010 at 5:34:52 PM
Surface Pattern on Modified Floor - No Skewing for Floor Plans |
Mon, Sep 12, 2016 at 7:45:11 PM
Surface Pattern Not Transferring to Model |
Fri, Jun 1, 2007 at 1:28:52 PM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
Model pattern override |
Wed, Nov 10, 2010 at 3:50:54 PM
Members: | 2115765 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
