63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> join geometry problem
62 Posts No Rating |
Hi, I wonder can anyone help with this: Sometimes when I want to use "join geometry" to connect 2 elements, Revit will not let me select the second element. Frequently I have to do this so that Hidden Line 3D images appear correctly, but at times i have problems making walls join each other, or making walls join to the topography. I think in terms of joining walls, the problem is because the arrangement of walls is quite complex. Its annoying however that I can't get the wall juntions to appear correctly in 3D.
Parallel walls join geometry do not cut opening |
Fri, Jan 31, 2020 at 1:32:48 PM
Cut / Join - Geometry (api) |
Tue, Jul 29, 2008 at 2:07:19 AM
Join geometry - Structural column with wall |
Sat, Dec 1, 2007 at 7:56:15 PM
Revit Structure 2008 SP2: Join Geometry on differnet beam families |
Wed, Sep 19, 2007 at 11:58:38 AM
walls won't join |
Fri, Oct 31, 2008 at 2:31:33 PM
Members: | 2056202 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
