34 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dormer Issue
Mon, Jan 25, 2010 at 11:20:04 AM | Dormer Issue
Arch145763
Hi,
I have a very specific problem I have attached a photo to help describe it.
I created dormers in the roof in the proper locations.  The dormers themselves serve an aesthetical purpose, they also help allow extra light into the building. They are ment to be built up from a rafter system, the cut off for the dormer walls should be at the rafters where they connect. This is not how the drawing turned out.
If you look at the image, inside the window we can see the walls protruding through the roof and hanging into the room below. I need these walls to not be there as they are not part of the intended structure. I need the walls to cut off at the rafters of the roof structure. How can I accomplish this?
Mon, Jan 25, 2010 at 11:23:40 AM | Dormer Issue
TKennedy
4 Stars: 7 Votes
Try attaching the walls to the roof (not sure if you can attach the base to a roof), and if that doesn't work edit the wall profile.
Mon, Jan 25, 2010 at 12:44:39 PM | Dormer Issue
4 Stars: 203 Votes
You can attach the "Base" wall to the roof...
Mon, Jan 25, 2010 at 1:16:13 PM | Typhoon
TKennedy
4 Stars: 7 Votes
Quoting Typhoon from 2010-01-25 12:44:38"
That's what I assumed, but I was feeling to lazy to actually test it.
Dormer wall attachment issue
Fri, Apr 15, 2011 at 1:42:01 PM
Dormer Roofs driving me mad
Mon, Aug 4, 2008 at 12:58:02 PM
Room bounding in a dormer.
Fri, Nov 8, 2013 at 2:57:01 PM
How can i get a dormer on this type of roof?
Wed, Mar 14, 2012 at 2:58:38 PM
DORMER ROOF
Sun, Mar 20, 2005 at 6:46:01 PM
Page generation time: 0.5632
