102 Users Online (100 Members):
Forums >> Revit Building >> Technical Support >> Model In-Place
Hey all, Ever since revit architecture 2010 was released with the new layout, i've been having troubles with in placed models and selecting the workplane for it to be drawn on. I use the model in-place feature to draw in the gable infills for the roof. However, when i try to do this now, I click (once in elevation view) Home > component (dropdown box) > Model In-Place > Select walls as category > Solid > Extrusion. In the older versions (07-09) a box now came up at this stage asking to select the workplane you wanted this drawn on. This however doesn't happen anymore. So what i really am looking for is how to set the workplane for an inplaced model? Cheers for any advice!
At the HOME tab on the right side you have the work plane, click in SET and choose the work plane you want...
thanks mate! champion!
Not able to place room copied from linked model |
Wed, Mar 18, 2015 at 8:10:37 AM
Create a new family from a 'model in place' |
Tue, Jan 17, 2017 at 12:57:22 PM
Help Can't create reveals on model in place wall |
Thu, Jan 5, 2017 at 1:22:53 PM
Change the MODEL IN PLACE - type Roof into curtain wall solar panel. |
Wed, Aug 14, 2013 at 7:03:04 AM
linked revit model disappears when I edit a floor or do an 'in place' model |
Mon, Dec 17, 2012 at 8:01:15 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
