51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> GETTING EXIT SIGN TO MOUNT IN CEILING
Sun, Jan 24, 2010 at 9:51:09 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
vinnygolfer
4.5 Stars: 4 Votes
hi, i'm using mep2010. i have downloaded from seek and from here ceiling mounted exit signs. i can't however get them to actually place into the model. i have gone into the families and made sure that they are lighting fixtures. but if i try to insert it, it shows in the tool bar as a component and will not attach to the ceiling, or a wall, or anything. could you please tell me what i'm missing. here is the file. if it didn't attach the file came from revitcity. i got it from the download page.
Try to learn at least one new thing every day
Mon, Jan 25, 2010 at 8:30:10 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
Do you own the ceiling or is it a link?
Are you placing it from a ceiling plan?
Mon, Jan 25, 2010 at 8:50:47 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
vinnygolfer
4.5 Stars: 4 Votes
the ceiling is from the Architectural link
Mon, Jan 25, 2010 at 8:52:47 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
vinnygolfer
4.5 Stars: 4 Votes
i didn't think that would make a difference since i can place light fixtures in there grid
Mon, Jan 25, 2010 at 9:40:50 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
You can only place face hosted elements on a linked object.
Mon, Jan 25, 2010 at 9:55:40 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
vinnygolfer
4.5 Stars: 4 Votes
so would i have to totally recreate this element, or should i just place a ceiling in the model to attach it to. as it is i'm going to have to make a fake ceiling in the vestibule to attach the pendant lights to. the vestibule has an arced ceiling and if i hang a pendent from it the pendent comes down at a scued angle that matches where it was attached.
Mon, Jan 25, 2010 at 9:59:27 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
Remember, there is a no thickness - no property ceiling that comes with Revit to use with exposed construction as a ceiling host.  It is one of the default ceilings.
Mon, Jan 25, 2010 at 10:01:24 AM | GETTING EXIT SIGN TO MOUNT IN CEILING
vinnygolfer
4.5 Stars: 4 Votes
thank you i'll try that
Parametric Exit Sign
Mon, Apr 14, 2014 at 12:38:12 PM
13
Exit sign symbol not showing in underlayed view
Wed, Jun 29, 2011 at 6:04:44 AM
Invisible annotations in Project files??
Tue, Jun 22, 2010 at 10:10:34 AM
Exit Sign Issues
Wed, Feb 8, 2012 at 1:31:45 PM
MODEL TEXT BACKWARDS
Mon, Feb 25, 2013 at 1:50:58 PM
Page generation time: 1.4652
