73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> can't demolish half wall???
37 Posts No Rating |
Anyone ever have this problem before. I tried lowering the cut plane so it crosses the 1/2 wall but still the demolish tool is not an option. No problems demo-ing full walls. Is it an unconnected wall thing? Any insight would be greatly appreciated. Thanks! Eric
![4 Stars: 19 Votes](/images/stars_4.gif) |
Revit cannot demolish half an object, but you can split the wall and put the two parts into different phases.
18 Posts No Rating |
Hmmm that is very strange, Im able to demolish half walls over here, are you sure they are referenced to the correct plane?
7 Posts No Rating |
Try changing the demolition phase in the element properties if the demolish tool doesn't work.
SOLVED! I was trying to demolish a new wall...dumb mistake. Thanks bgdragon et al.
Un-Demolish |
Tue, Jan 2, 2007 at 4:16:58 PM
Demolish wall alyer |
Fri, Aug 1, 2014 at 10:37:24 AM
demolish door with out infilling opening |
Fri, Jun 5, 2015 at 9:30:39 AM
Clean up Demolish Wall... |
Mon, Nov 8, 2010 at 7:52:01 PM
Demolish Tool |
Thu, Sep 13, 2012 at 6:20:41 PM
Members: | 2016974 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
