38 Users Online (37 Members):
Forums >> General Discussion >> Wishlist >> Element Visibility Setting in Project
98 Posts No Rating |
I think it would be nice to have the same kind of Visibility control that you have in a family be present within a project. Perhaps this could get out of control, but I think it would be nice to be able to pick an object and have it show up only from certain views or with a certain detail level. Without having to make the change in every view. The example that sparked this for me was those annoying infill pieces of walls that occur when you demo a window or a door.
![3 Stars: 10 Votes](/images/stars_3.gif) |
Have you a workaround with that? Got the same issues. Thanks.
Motto: "No Post left behind" |
The only solution I've come up with is the annoying and obvious one: if the infill pieces get in the way, hide the element in each view. Not very elegant, but I haven't found any way to handle those infills seperately from the walls they're a part of. I have found that if you're careful you can get a new opening to cut both the infill and the host wall so that the infill doesn't get in the way, but it can be fussy. The elevation is usually the place to do that. HTH.
Hide Mullion Profile When the Visibility Setting is Fine |
Mon, Mar 13, 2017 at 10:32:48 AM
Symbolic Element Visibility |
Tue, Feb 4, 2020 at 6:42:28 AM
LOSING USER VISIBILITY SETTING AFTER SYNCHRONIZING |
Tue, May 29, 2012 at 10:08:53 AM
Yes/No visibility parameter |
Fri, Jun 20, 2008 at 1:24:11 PM
Visibility setting for a arch seal |
Wed, Oct 19, 2016 at 11:22:56 AM
Members: | 2019203 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
