37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> why the line?
Thu, Jan 21, 2010 at 12:00:17 PM | why the line?
Steve123
I created a 5'x4' concrete pilaster that is notched out at the top to allow a beam to pass. To create the pilaster I first modeled the 5'x4' pilaster to a certain elevation. Then I duplicated and created a new smaller size pilaster and entered it's base elevation so it sat on top of the 5'x4' pilaster which created the notch I was looking to produce. Seeing that the smaller pilaster was created by duplicating from the larger pilaster, the material, usage and other parameters are the same. Why then do I see a line when the faces of the pilasters are in the same plane? See attachments. I'm using Revit Structure 2010. Is their an easier way to produce this notch? I'm new at revit.
Thu, Jan 21, 2010 at 12:07:28 PM | why the line?
TKennedy
4 Stars: 7 Votes
Have you tried the Join tool? Stuff doesn't always automatically join.
As for creating the notch, I think I would copy the existing pilaster family, then add a void at the top, constraing it to reference planes and adding some parameters to control its size.
Thu, Jan 21, 2010 at 12:08:36 PM | why the line?
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Try to "join geometry". that should join them and eliminate the "line" (only if they have skin/thickness - to properly join). If that doesn't work... you can model you pilaster all the way up and just use a "void" to give you that notch you want.
 "If you tell the truth, you don't have to remember anything"
Anyone got line styles that will automatically insert a letter....
Wed, May 2, 2012 at 8:29:56 AM
Line Patterns
Tue, Aug 9, 2005 at 3:08:30 PM
Any Suggestions For Line wt Table set up and Line Style Names
Thu, Jun 5, 2008 at 7:01:45 AM
Line types
Thu, Nov 17, 2005 at 2:53:43 AM
Basic Line Drawing Question
Thu, Jan 7, 2016 at 11:48:01 AM
Page generation time: 0.8415
