38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> homerun tag
Thu, Jan 21, 2010 at 10:28:38 AM | homerun tag
vinnygolfer
4.5 Stars: 4 Votes
hi, using mep 2010, is it possible to tag a single outlet with a homerun wire. i can't seem to get the homerun to show up unless i have more than one device connected.
Try to learn at least one new thing every day
Thu, Jan 21, 2010 at 2:06:38 PM | homerun tag
chuckbradley
Due to difficulties and time wasted using the homeruns, tick marks, and conduit in Revit, we changed the way we do things around here.  We are now putting a panel-circuit# tags next to each electrical item that is connected, minus switches and such.  This works pretty slick and looks really nice.  The only time we use wires is to indicate what lights are controlled by what switch/es.  That is still a bit of a pain too, but doesn't waste nearly as much time.
Revit just doesn't do a good enough job on it's own with these things and when you think about it, showing the conduit can be pointless considering the contractor will likely come up with his own way to wire it up.
Thu, Jan 21, 2010 at 2:15:47 PM | homerun tag
vinnygolfer
4.5 Stars: 4 Votes
thanks for the input. my computer was having a case of the i don't want too's. so i got out and went back in, and that cleared it up. now i wish the templete that they have for a panel schedule looked as good as our own from autocad. dreaming i know.
Multi-wire homerun tag out of order
Fri, Dec 9, 2011 at 10:18:58 AM
Homerun from junction box
Mon, May 14, 2012 at 10:08:42 AM
Homerun arrows on elektrical wiring
Wed, Jul 21, 2010 at 3:40:15 PM
Circuit Homerun
Tue, May 5, 2009 at 1:40:58 PM
How to Wire Multi-Circuit Receptacles Within 1 Conduit?
Mon, Mar 21, 2011 at 1:19:07 PM
Page generation time: 0.4810
