41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof with variable thickness on sloping framing
Wed, Jan 20, 2010 at 8:23:55 AM | Roof with variable thickness on sloping framing
lpnoble
I have a simple roof with a one directional gental slope. I want to incerase the thickness in certain areas via variable thickness layer in the roof type to add crickets and low spots for drains (this is a tapered insulation on 1/4" sloped roof). This works great on a flat roof with no slope defining edges. Once I add slope I cannot modify the thickness. I thought about making the roof on a sloping work plain but that didnt work eather.
Any way to do this?
Wed, Jan 20, 2010 at 10:12:07 AM | Roof with variable thickness on sloping framing
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Do do crickets... i would do the in-place family using sweep blend tool. (I know Daryl from "dgcadd" did a video tutorial on this) try to search for it here.
 "If you tell the truth, you don't have to remember anything"
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:59 PM
Sloped solid roof with variable thickness
Tue, Feb 21, 2017 at 4:09:25 PM
Revit 2010 Sloping Roof in in two directions at once
Fri, Aug 20, 2010 at 8:34:01 PM
creating subtle slopes for a flat roof in Revot 2011
Tue, Mar 8, 2011 at 8:26:34 AM
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:45 AM
Page generation time: 0.4552
