37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Schedules and areas
Tue, Jan 19, 2010 at 12:42:58 PM | Schedules and areas
TKennedy
4 Stars: 7 Votes
I have a project where I am tagging/scheduling equipment. I need to split the schedules up on sheets so that only the equipment on the sheet is in the schedule on that sheet. The way I am doing it now is I have a text parameter for all the equipment where I enter the sheet number, and the schedule on that sheet filters by that parameter. I would like to make this more automatic, so if I place a piece of equipment in the ground level kitchen it only shows up in the schedule for that area, and I don't have to do anything else. I tried using rooms (I can add the room name parameter to the schedule and filter by it), but the equipment doesn't seem to be tied in any way to the room. Is there another way to do this, or am I stuck with the way I came up with?
 The schedule is a multi-category schedule, and the stuff I am scheduling is mostly specialty equipment, with a few plumbing fixtures, if that makes any difference.
Tue, Jan 19, 2010 at 12:50:29 PM | Schedules and areas
I schedule furnishings all the time by room.  Just add rooms to your schedule to filter by and hide that column.
Tue, Jan 19, 2010 at 1:40:29 PM | Schedules and areas
TKennedy
4 Stars: 7 Votes
Ok, knowing that the room method should work got me looking closer, and it turns out the schedule phase was set to project completion instead of new construction. Seems to be working now.
area plans & schedules help
Thu, Oct 8, 2009 at 12:56:32 PM
multiple schedules
Tue, May 1, 2012 at 1:04:43 PM
Areas and area schedules in Revit 2013
Fri, Mar 18, 2016 at 7:27:56 AM
Wall tile areas
Mon, May 4, 2009 at 7:19:26 AM
SQUARE FOOTAGE (AREA) SCHEDULES
Thu, Sep 1, 2016 at 7:01:35 AM
Page generation time: 1.9484
