76 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Rotating Views on Sheet
Tue, Jan 19, 2010 at 12:08:52 PM | Rotating Views on Sheet
Vanessa22
I've rotated my viewport on a sheet to make it fit, but it has also rotated the title....is there anyways of rotating the title individually so that it is right side up??
THanks
Tue, Jan 19, 2010 at 12:20:20 PM | Rotating Views on Sheet
KingRevit
4 Stars: 12 Votes
select the viewport and change its type to one without a title.
then either just place in some text or duplicate the view and turn off all the items in vis grapics and place that one on top of the other view.
Tue, Jan 19, 2010 at 12:30:56 PM | Rotating Views on Sheet
Did you want to rotate the view or rotate the view on the sheet?  There is a difference.  When you rotate the view on the sheet, all text is rotated with the view including the view title.  If you activate the view and rotate the view by selecting the view crop and rotating, all the text will stay readable and only the model and detail elements will rotate.
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:47 AM
18
Rotating Views on a Sheet -180
Tue, Nov 5, 2013 at 9:44:27 AM
Thu, Jun 15, 2006 at 10:01:09 PM
Rotating Project North and Sheet view North not rotating
Mon, Oct 12, 2009 at 9:34:26 AM
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:57 PM
Page generation time: 0.6032
