26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit MEP 2010 Ceiling Plans and Ductwork/Air Devices
Tue, Jan 19, 2010 at 8:56:50 AM | Revit MEP 2010 Ceiling Plans and Ductwork/Air Devices
bbaiotto
I am using Revit MEP 2010 for modeling of mechanical systems.  Currently I have the plan view set up as a floor plan with the underlay set as a reflected ceiling plan and the model graphics set to hidden line (also same result when model graphics set to wireframe). With this configuration the ceiling plan trims the ductwork, air devices and all mechanical equipment even though they are above the ceiling.  The only items that trim the ceiling are the call out tags.  The RCP is drawin above everthing else.
How can I get the ceiling plan to trim around the ductwork, air devices and mechanical equipment.    In AutoCad I would simply set the RCP draworder to back, but there doesn't apper to be a similar command with Revit.
(I do not set the plan view as a ceiling plan, since in this mode the model "looks up" and the hidden lines are trimmed backwards)
Thanks,
Bert
Shading Ductwork and Air Terminals on plan
Tue, Oct 19, 2010 at 3:08:32 PM
Return Air systems help? Please
Tue, Feb 9, 2010 at 11:42:41 AM
No NUrsecall Familes In revit Mep 2010??
Tue, Oct 22, 2013 at 12:37:01 PM
Ductwork connected to air device displays flow in one model but not another
Fri, Nov 15, 2013 at 7:33:41 AM
REVIT MEP - Outside Air
Thu, Apr 24, 2008 at 11:57:55 AM
Page generation time: 1.7870
