56 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> mirror text
Wed, Sep 7, 2005 at 9:31:03 AM | mirror text
karok
Is there a way to mirror text, so that it will be backwards?
Wed, Sep 7, 2005 at 5:57:52 PM | RE: mirror text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Only model text can be shown backwards. I can't imagine why anyone would want to show normal text backwards??
Thu, Sep 8, 2005 at 6:36:54 AM | RE: mirror text
karok
it is our offices symbol for a double angle a backwards l, and a l beside each other. see the attached pic
Thu, Sep 8, 2005 at 10:51:24 AM | RE: mirror text
TomDorner
4.5 Stars: 25 Votes
Why does it have to be text? Why not create an annotation where the double L's are simply lines and there is a parameter for the angle size? I created one for you to look at and attached it. It is in version 8.1, load it into your project, place it as a symbol and fill in the angle size parameter. You may need to tweak it to better resemble your office standard, but it should get the job done. HTH Tom
Thu, Sep 8, 2005 at 6:13:08 PM | RE: mirror text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
alternatively you could edit a font to include the backward L as a character... Program such as Fontlab's Typetool 2 is good at this... There is also one already built into the Arial font Alt+2518 & Alt+2514 Post edited on 2005-09-08 18:15:31
Mon, Sep 19, 2005 at 4:56:58 PM | RE: mirror text
karok
thanks guys. the brass descided to go to a new program days before a new project started, and want to use it with the new program. so im kinda winging it.
tEXT jUSTIFICATION
Wed, Jun 20, 2018 at 11:10:09 AM
using the mirror comand [ 1 2 ]
Thu, Oct 15, 2009 at 9:13:36 AM
17
Model Text
Mon, Jan 14, 2008 at 1:30:18 PM
HELP... need to mirror a plan
Wed, Jul 2, 2008 at 12:27:55 PM
12
Mirror Material in Revit not Working
Tue, Sep 23, 2014 at 5:49:41 AM
Page generation time: 14.1931
