Forums >> Revit Systems >> Technical Support >> Scheduling Shaft openings indicating its clear dimensions
Tue, Jan 19, 2010 at 2:17:12 AM | Scheduling Shaft openings indicating its clear dimensions
Bhavani
Bhavani Avatar
Here is a requirement which wants us to list all the shafts ( shaft tags ) with its clear dimensions and the levels they start and terminate in the following format as a schedule to be included in the drawing sheets.
NAME    | CLEAR DIMENSIONS   | STARTING   | TERMINATION
RSP 12 | 1000 MM X 2000 MM | BASEMENT 1 | LEVEL 10
I tried to create a shared instance parameter where I could input data for the shaft opening manually and make it appear in the schedule. But the tricky part is its done manually and everytime a shaft opening is revised i have to edit the paramenter's content. Is there a way to parametrically dimention the shaft?  Crying like how we do in creating parametric families ) and transfer tht value to the schedule? This way the dimensions get updated int he schedule automatically whenever there is a revison.
Thanks Smile
Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 8:16:14 PM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Visibility of Shaft Openings in a detail view
Fri, Apr 17, 2009 at 11:13:42 AM
Symbolic Lines not showing up in Shaft Openings
Thu, Jul 3, 2008 at 11:08:46 AM
SHAFT OPENINGS
Thu, May 9, 2013 at 3:34:41 PM
Page generation time: 0.3898
