55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> group problem instande not cutting anything
29 Posts No Rating |
Hi, I'm currently working on a large project with a lot of identical rooms. I created groups for the rooms and everything worked fine so far. But now i have to edit the doors in the groups and keep getten error messages. After i change the doortype and finish the group i get the massage "instance of [door family] not cutting anything. And the doors of some families dissapear. Some doors dissapear and others don't, and the number of groups that are affected varies with serveral attempts. The doors are not completely gone. when I hover the mouse over the groups i can see the door as if it is excluded from the group. But i can't include it to the group anymore.
Your problem is exactly as noted. When you changed your door type, the new type is no able to find an appropriate host. Look at insertion point of the two door types... also opening cut location.
Edited on: Mon, Jan 18, 2010 at 9:15:36 AM
How do i find the insertionpoint? The help file says it's the origin of a family but i don't know how to find it in the door family. And to what exactly do i have to pay attention when looking at the insertion point and the opening cut. btw this problem doesn't only occur when switching between two doors, but als sometimes when editing a instance parameter of a door.
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ] |
Wed, Nov 23, 2016 at 3:27:29 PM
15
edit group panel missing |
Tue, Jan 17, 2012 at 2:54:43 AM
12
Group instances of the same type do not contain identical members |
Sat, Jan 23, 2016 at 7:57:37 PM
Floor Plan - Window Cutting Problem |
Fri, Jan 7, 2011 at 4:16:59 PM
GROUP questions |
Fri, Dec 5, 2008 at 4:12:28 PM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
