Forums >> Revit Building >> Technical Support >> wall family
![WYS1WYG Avatar](user_avatar/87652.jpg)
![3 Stars: 11 Votes](/images/stars_3.gif) |
RAC 2010 when you create a wall as a family how do you add wall assemblies and layers like you do with a system wall?
![3 Stars: 10 Votes](/images/stars_3.gif) |
Hi, Don't exactly know what you mean. Wall is a system family and is inherent (built-in) in your model. 2 types of families in Revit, system and hosted. Wall is a system family and I think for now we cannot create system families only duplicate them and modify. For now, we can create a family that is using a floor based template that looks functions like a wall. To define assembly in that kind of wall, you have to manually assign each and every element property while creating them and must behave parametrically-that's a lot of trouble, I think.Can you be more specific of your scenario?
mhans- thanks for trying to help.. i think you are saying there are only "system" walls.. please see the wall i created that is NOT a system wall..
Yes, you can actually make an in place model and categorize it as a wall. But you cannot assign or tag combination of materials like you would in a system family wall. You can only assign Function & Identity data to your in-place wall model but cannot define its material/structural composition. And in an in-place wall, like your wall1, will not respond to trim, extend, split like a real wall. May I know your reason for trying to create your own wall assembly?
thanks again mhans- i'm thinking i can design any wall shape i want as an in-place family wall and build a generic model that can more easily be modified in a design stage.. and i'm wondering how that kind of model can be converted to construction details when it is ready.. are you saying once you start with an in-place wall it can never become a real wall?
In-Place Elements Yes, you are right. You cannot convert an in-place wall to a system wall later on. There is no option to duplicate or match prop an in-place wall with another in-place wall. A system wall has more functionality like core face exterior/interior, base/top constraint, base offset, inserts/end wrapping, and the likes that are very helpful in changing wall types later on in the CD phase. For schematics and DD, your in-place wall wil come in handy, but once you are itemizing your wall components, you will find yourself redrawing again those walls. In-place elements are custom elements that you create in the context of a project. Create an in-place element when your project needs unique geometry that you do not expect to reuse or geometry that must maintain one or more relationships to other project geometry.
so then how can an in-place wall "come in handy" if it can never be used to represent a real wall and has to be torn down and replaced with a system wall?
Pls. see attached for a generic sample. If you will be doing the CD too, system walls will later on give you more flexibility. If you're just presenting your ideas, your in-place wall will just be fine.
Revit 2008 wall mounted family placement issue |
Mon, Jun 20, 2011 at 3:19:51 AM
Wall hosted family can't be hosted on curtain wall?! |
Fri, Oct 22, 2010 at 7:13:04 AM
Family with Wall Protrusions |
Tue, Jan 24, 2006 at 5:25:38 PM
Wall based family sinks into the wall |
Fri, Aug 5, 2022 at 1:50:39 PM
WALL BASED FAMILY |
Fri, Sep 20, 2013 at 3:56:04 PM
Members: | 2022537 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
