29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Grid Bubble Labeling Issue
Fri, Jan 15, 2010 at 2:42:37 PM | Grid Bubble Labeling Issue
jimBVH
We are using Revit Structure and trying to rename grids.  However, we cannot rename some grids to certain numbers or letters because the program states that the particular label is already being using.  We've been all throught the model and cannot find duplicate labels.  We tried purging and still can't change the label.
 Anyone have this problem?  And more importantly has anyone solved this probem.
Thanks
Fri, Jan 15, 2010 at 3:43:18 PM | Grid Bubble Labeling Issue
This is not a revit problem.  You may have a column line with the bubbles turned off or it may be very short or even out beyond your view.
Multi Segment Grid Line Bubble Issue
Wed, Dec 11, 2013 at 2:52:12 PM
Grid Bubble formatting between projects
Sun, Oct 26, 2014 at 8:33:05 AM
Different Grid Bubble for different scale views?
Thu, Dec 12, 2013 at 5:42:14 AM
Column grid text too wide to fit in bubble
Thu, Jul 1, 2010 at 8:32:07 AM
Grid Bubble Trouble Revit 2015
Fri, Sep 25, 2015 at 7:25:44 AM
Page generation time: 0.7480
