74 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Solid Fill Hatch
Fri, Jan 15, 2010 at 11:43:23 AM | Solid Fill Hatch
Jhui
I tried searching thru RevitCity for some previous threads on this subject but I couldn't find one that had the same error, if you do find one please forgive this thread and link it. Smile
I have a detail family that is basically a masking region which I load into a face-based lighting fixture. On my reflected ceiling plan, it shows up just fine. When I add another masking region family that has a solid fill (black) to it and load that into my lighting fixture, that shows up just fine. However, when I load the fixture family and place it into my project, the solid fill is completely ignored. I tried some other suggestions I found here in RC such as making a dense line pattern but when it comes into the project, that also gets ignored.
Any help on this disappearing solid fill?
Fri, Jan 15, 2010 at 12:11:45 PM | Solid Fill Hatch
TKennedy
4 Stars: 7 Votes
Is there a hatch type in the project with the same name?
Fri, Jan 15, 2010 at 1:36:07 PM | Solid Fill Hatch
Jhui
There is and I checked it. Its black.
Fri, Jan 15, 2010 at 4:16:05 PM | Solid Fill Hatch
cbieser
1 Stars: 1 Votes
Check your visibility graphics to make sure that detail items are visible.
Mon, Jan 18, 2010 at 11:40:09 AM | Solid Fill Hatch
Jhui
Detail items are visible. Check.
Its the solid fill (black) filled region that is not showing up when loaded into the project. I can hatch it with a different pattern and that shows up but its as if anything that is close to solid black shows up as white. That is what I'm trying to figure out.
Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:31 PM
Solid fill and concrete hatch
Wed, Mar 28, 2012 at 3:19:54 PM
Lost Solid Fill Pattern
Wed, Apr 9, 2008 at 7:58:47 AM
Making solid hatch partly transparent...
Fri, Nov 9, 2007 at 4:00:06 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Page generation time: 1.6871
