144 Users Online (143 Members):
Forums >> Revit Building >> Technical Support >> Multiple Wall Type Callouts
5 Posts No Rating |
I have a floor plan I am working on, and I am currently putting in the wall type symbols. There are several small spaces that need to be tagged, so is there a way to stem more than one line off of a single tag? Help would be much appriciated. Thanks!
- Doweth! [Homer J. Simpson] |
I usually slam one tag on top of the other... they will automatically line up.
5 Posts No Rating |
This worked! But there seems like there should be an "official" solution. Seems like when it asks you to "Pick Host" you could select more than one item.
JHuman wrote: "Seems like when it asks you to "Pick Host" you could select more than one item." If you think about that, this can never - should not happen. These tags are not static. If they were, they could do what you want but these tags read their data from what you point to - just impossible to do with multiple items.
multiple section callouts |
Wed, Jun 4, 2008 at 9:04:18 AM
Are Callouts Vew Specific? |
Wed, May 12, 2010 at 3:56:06 PM
applying multiple hatch to wall |
Wed, Jan 2, 2013 at 5:35:10 AM
Same Door Type, Different Frame Type |
Thu, Jul 24, 2008 at 3:16:26 PM
Match Type on multiple elements |
Thu, Feb 12, 2009 at 7:56:47 AM
Members: | 2030717 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
