83 Users Online (81 Members):
Forums >> Revit Systems >> Tips & Tricks >> Piping flow arrows
![4.5 Stars: 3 Votes](/images/stars_4.5.gif) |
I am looking for some suggestions on how to place flow arrows on piping. Can I make it part of the pipe tag?
![5 Stars: 3 Votes](/images/stars_5.gif) |
Sure, you could add flow arrows to a pipe tag, you could create them as symbols and then add the symbols to the tag. But, they would be a pain because of their limited flexibility. You would have more flexibility for placement if you created a separate flow arrow pipe tag. You can have as many different types of pipe tags as you like. Just switch to the one you would like to have current place your tags and then switch to another type. You can load the multiple tags you created into a project on the Annotate tab > Tag panel > Tag flyout (at the bottom of the panel).
Jill Bernhardt Blog: The BIM Bulletin |
1 Posts No Rating |
Is it possible to make a flow arrow that knows which way the pipe is flowing? If not, is there a way to use a flip control to control the direction it is pointing? I can't seem to get the flip control option to come up on my ribbon in the family editor when working on a tag. What am I missing?
![Eddieboarder91 Avatar](user_avatar/37222.jpg)
![4 Stars: 8 Votes](/images/stars_4.gif) |
yes you can use the flip arrow you could also use visiblity to control what you are seeing in the family... Check out what we did when we created the content for Brady a pipe sticker mfg http://seek.autodesk.com/search/brady?source=SearchBox&q=category%3Astd%3Aoc1%3A23.40.90.11.14
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
REVIT MEP Flow arrows |
Wed, Sep 7, 2011 at 4:14:45 PM
Piping - direction of water flow |
Mon, Nov 15, 2010 at 7:57:19 AM
Piping loops |
Wed, Apr 30, 2008 at 12:35:59 PM
How to limit flow-rate and control flow direction in Ductowork "T" fitting |
Thu, Oct 16, 2014 at 3:17:26 PM
RevitMEP 2010 - Fixing Errors - "Check Duct Systems" + "Check Pipe Systems" |
Fri, Sep 18, 2009 at 11:59:29 AM
Members: | 2022302 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
