46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Lower an entire floor's steel 1"
Wed, Jan 13, 2010 at 2:08:03 PM | Lower an entire floor's steel 1"
mike321
How can I pick the steel of an entire floor and lower it 1"? When I put a window around the floor with only the beams on the element properties dialog box is empty when it opens.
Thu, Jan 14, 2010 at 7:42:43 AM | Lower an entire floor's steel 1"
If these are tied to a structural level, you could just lower that.  If not, you could add a structural level and move all the beams to that level.
Mon, Jan 18, 2010 at 4:51:38 PM | Lower an entire floor's steel 1"
emgeeo
3.5 Stars: 7 Votes
Are you sure you filtered everything out?
At any rate- when I frame a floor I typically create levels for my TSE and my TBE.  This provides me with the ability to constrain elements and control them easily.  If I need to raise/lower an elevation 1", I just change the elevationt the level is constrained to.  It's also nice for constraining floors to my slab.
Mirroring entire project- "copy" check box greyed out?
Sun, Apr 23, 2006 at 6:44:58 PM
Dimension "entire wall"
Fri, Jul 28, 2006 at 3:30:05 AM
sloped steel?
Thu, Apr 8, 2010 at 5:51:26 PM
Room's lower offset is above the Computation Height
Thu, Jan 26, 2017 at 3:53:35 PM
Walls, Split regions and Materials
Fri, Jan 20, 2006 at 3:13:13 PM
Page generation time: 2.4426
