75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ceiling Heights Scheduled - Problem: Sloped Ceilings
Wed, Jan 13, 2010 at 8:55:28 AM | Ceiling Heights Scheduled - Problem: Sloped Ceilings
jgfry
There are a number of helpful posts regarding how to create a parameter in a Room Schedule so that you can have a Ceiling Height variable automatically placed in your Room Schedules. And the problem has been documented that sloped ceilings are a problem. My question is, is there a solution? Is there a way that you can manually change the field inside your schedule to say "Varies" or any other hand fed content from a calculated field?
 Or, has anyone come up with another work around to this problem?
Thanks.
Wed, Jan 13, 2010 at 9:28:50 AM | Ceiling Heights Scheduled - Problem: Sloped Ceilings
The work around is to use a manual text field instead of an automatic.
Recessed Lights in Sloped Ceiling
Thu, Dec 13, 2007 at 10:23:29 AM
Ceiling heights in schedules
Thu, May 26, 2005 at 9:26:43 PM
Lights and Sloped Ceilings
Mon, Feb 14, 2011 at 4:47:19 PM
Ceiling Plan View Range
Sat, Feb 23, 2008 at 9:22:54 PM
Annotating high and low points of a sloped / vaulted ceiling
Tue, Jun 5, 2012 at 1:55:06 PM
Page generation time: 1.3455
