69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof Joins for crickets on roof
Tue, Jan 12, 2010 at 2:36:03 PM | Roof Joins for crickets on roof
quinn
See attached image for current condition.  I have attached one roof with the ridge condition to my main roof in order to create a natural cricket.  The problem is the crickets terminate at the parapet wall where the scuppers will be.  In order to join roofs you cant have one roof overlap the other and if i pull the cant roof to the west to clear the other roof i have to have it inside the parapet wall with a very small width so i can select edges for slope.  Is there a better way to do this? Im ok with the roof slightly within the parapet wall but it seems like there should be another way.
Flat roof with crickets
Mon, Jun 9, 2008 at 3:50:46 PM
Roof Crickets (How to do them)
Wed, Nov 4, 2009 at 3:43:48 PM
crickets for complex roof w/ multi slopes attached to beams
Fri, Aug 1, 2008 at 3:13:46 PM
adding crickets to a sloped roof structure
Mon, Oct 16, 2017 at 9:28:30 AM
sloped subroof with crickets
Tue, Nov 20, 2012 at 4:00:34 PM
Page generation time: 16.0944
