117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> Rod iron Fencing
Tue, Sep 6, 2005 at 12:35:02 PM | Rod iron Fencing
lwasden
I am looking for a nice looking rod iron fencing or railing. Is there anybody who can help me out? Thanks!
Tue, Sep 6, 2005 at 12:43:31 PM | RE: Rod iron Fencing
TomDorner
4.5 Stars: 25 Votes
Take a look at the railing samples at this Autodesk site: http://revit.autodesk.com/library/html/index.html Look under Revit samples There may be something close to what you need that you can use as-is or modify to your liking. HTH Tom Post edited on 2005-09-06 12:44:12
Tue, Sep 6, 2005 at 1:46:00 PM | RE: Rod iron Fencing
lwasden
Thanks for your reply. When I tried to open the Revit Smaples files I was told that the files were saved in a later version and cannot be retrieved. Do you have any ideas why it says this?
Tue, Sep 6, 2005 at 2:08:25 PM | RE: Rod iron Fencing
TomDorner
4.5 Stars: 25 Votes
Because they are in a later version than what you are using. The current Revit version is 8.1 and since we are all on subscription that is the version you should be using. Tom
Tue, Sep 6, 2005 at 2:21:38 PM | RE: Rod iron Fencing
hahnmj
There are archived libraries on the content distribution center, so if you are using a earlier version of revit you can find that sample for 6.0, 7.0 and 8.0.
Tue, Sep 6, 2005 at 3:24:29 PM | RE: Rod iron Fencing
TomDorner
4.5 Stars: 25 Votes
The railing and stair samples were posted in version 6.0 after the Autodesk University class were they were used in to introduce 6.0 features. I believe they are still in 6.0 format. Tom
Hanger Rod
Thu, Jun 21, 2018 at 8:00:31 AM
Tube Steel Fencing
Mon, Aug 14, 2006 at 5:19:18 PM
Threaded rod
Fri, Aug 18, 2017 at 1:43:29 PM
Fencing to follow topsurface levels
Mon, Feb 2, 2009 at 12:44:30 AM
Corrugated Iron roofs
Sun, Jul 31, 2005 at 10:26:15 PM
Page generation time: 0.1953
